I would like to ask you If you could help me with the error that I attached here.
I have modeled my wall as a component element. There is a convergence error; however, I couldn't figure out the reason.
Best regards,
Onur Arslan
Convergence error
Convergence error
- stko_CS_CL.PNG (97.97 KiB) Viewed 257 times
Re: Convergence error
Hi Onur,
Based on the error, it seems that you included a displacement control as an integrator by choosing a target displacement of 0.2 units, however, you did not insert a load. To correct the problem, you must add a load as a condition first, before running the analysis.
I have attached a screenshot where you can see the specific error code.
I hope this helps!
I hope this helps!
- image (3).png (97.44 KiB) Viewed 254 times
Hello HannahCartwright,
Thank you for your help.
I fixed the problem and it run after that.
Best regards,
Onur Arslan
Best regards,
Onur Arslan
