Installation errors
Installation errors
Hi there,
When trying to install the software I get the error depicted in the attached figure. Could you advise how to overcome this?
- Capture.PNG (29.05 KiB) Viewed 13970 times
Re: Installation errors
Hi Yara
This kind of error can happen if
1) you are re-installing STKO while the previous installed version is running (is this the first time you install STKO?)
2) or if you don't have administrator rights on your PC (do you have administrator rights on the PC?)
if these are not the cases, try to download STKO again, probably the downloaded file got corrupted (or, like in my case, make sure you don't have an anti-virus that blocked the execution of the downloaded STKO installer)
Let me know if you fix this error
Many thanks Ricardo!
I ran it as admin and it works now.
I am trying to add a screenshot and picture but it does not work.
Problem is that
I opened and run the STKO. But when I open it again it is unable to open and gives the error message as given below:
1.1.Exception during activation
"Activation limit exceeded for this key".
Problem is that
The screenshot of the window showing the error is added in attachments.
Problem is that
Problem is that
- Picture1.png (457.04 KiB) Viewed 13826 times
- Picture1.png (355.67 KiB) Viewed 13826 times
Hi Asad,
Now try again! The problem should be solved.
Yes, it is working now.
More than thanks.
More than thanks.
Hi, I tried to open the software but it is unable to and gave the error message:
Please click on System Info button that appears in the window that shows the error. And post the code that you see
The code is: 2B4A75E8D8EEBE00092A4260751EDF6096604494480A39B0
