I developed the masonry wall model shown in the image. I used hexahedral 20 node elements. The problem is that when I ask STKO to write the input files, 'elements.tcl' file is empty. Do you know what could be happening here?
Agustín
Hexahedral 20 node element mesh
- model.JPG (139.09 KiB) Viewed 2463 times
Re: Hexahedral 20 node element mesh
Probably you did not assign the element property to the solid. Note that generating a mesh is not sufficent, you must create and assign an ElementProperty that basically tells STKO what OpenSees Element to use.
Thanks joseP.
