PML element in STKO
Zouatine
Re: PML element in STKO
Post by Zouatine » Fri Sep 26, 2025 7:18 am
Dear Stko Team ,
Thank you for your response,
I did not pay attention to the new updated as it was edited from the previous response.
As you mentionned earlier in your replay, that the implementation is quite stright forward for the PML. Can we do that for the 2D case . I guess this would help a lot to solve some 2D problems and quite easy to compare the implementation.
Thank you ,
Zouatine
Post by Zouatine » Tue Nov 04, 2025 7:31 am
Hello STKO Team,
Is there any update on the posted issue for 2D case.
Thank you,
Post by STKO Team » Wed Nov 19, 2025 8:40 am
Dear user,
The implementation is almost done, we're doing some testing. It should be out by the end of the month
Zouatine
Post by Zouatine » Fri Nov 21, 2025 9:16 am
Thank you for your response, I am looking forward to it.
Zouatine
Post by Zouatine » Mon Dec 08, 2025 7:54 am
I want to kindly follow up to check whether the implementation is done.
Thank you ,
Zouatine
Post by Zouatine » Sun Sep 27, 2026 3:03 pm
Hello STKO Team,
I hope you are doing well.
I want to kindly ask whether there is an update about this topic? as you mentioned that earlier that the implementation is quite straight forward, is it now implemented?
thank you
