hello,
I’m trying to extract the soil stresses so I can plot them, but I’m not able to.
Here is my model — it runs correctly, but I can only plot the displacements.
earth Stress
earth Stress
- m2.rar
- (97.68 KiB) Downloaded 31 times
Re: earth Stress
ask for material.stress and/or material.strain in the element results in the MPCO Recorder
Re: earth Stress
Thank you for the reply .
Is it also possible to plot the stresses and/or strains in the same way as the displacements from the MPCO Recorder results?
Re: earth Stress
Sure, stress (or any other result defined in Gauss Points) can be visualized:
- With gauss plot: In this case the result will be exactly the one on the gauss (integration) point as computed by OpenSees
- With surface color map: in this case the result will be extrapolated from gauss points to nodes
