Material Tester error
Tharuki
Post by Tharuki » Tue May 13, 2025 5:51 pm
Whenever I assign concrete material for concrete cover in RectangularFiberSections section i get an error as
Error:
Traceback (most recent call last):
File "C:\Program Files/STKO\external_solvers\opensees\physical_properties\sections\RectangularFiberSection.py", line 1024, in runTesterConfined
self.tester.run()
File "C:\Program Files/STKO\external_solvers\opensees\physical_properties\utils\tester\Tester1D.py", line 338, in run
os.remove(temp_output_file)
FileNotFoundError: [WinError 2] The system cannot find the file specified: 'C:/Users/Athula/AppData/Local/ASDEA Software Technology/STKO/Tester1D/output.txt'
What can I do for this?
Re: Material Tester error
Post by STKO Team » Thu May 15, 2025 4:01 pm
What concrete model are you using?
Can you share your file?
Tharuki
Post by Tharuki » Thu May 15, 2025 6:22 pm
I used concrete01 and the error is generated when I assign the concrete material to the section. This is the file.
RFBuildingFrame.zip
(28.58 KiB) Downloaded 106 times
Post by STKO Team » Fri May 16, 2025 9:09 am
Thank you for finding this bug.
We have fixed it and will be available to all users in the next STKO version.
In the meantime, you can:
  • Unzip this file in C:\Program Files\STKO\external_solvers\opensees\physical_properties\sections
    replacing the existing one
    RectangularFiberSection.zip
    (15.96 KiB) Downloaded 104 times
  • Unzip this file in C:\Program Files\STKO\external_solvers\opensees\physical_properties\utils\tester
    Tester1D.zip
    (8.5 KiB) Downloaded 99 times
Tharuki
Post by Tharuki » Fri May 16, 2025 4:45 pm
Thank you so much for your support!
Post by STKO Team » Mon May 19, 2025 7:53 am
