Cannot find pdm.dll
Cannot find pdm.dll
Hallo,
I tried to run a file and received an error message saying that the pdm.dll file could not be found. However, the file is located in the folder C:\OpenSees-Solver\OpenSees3.7.0\plugins. Does anyone know what this problem is?
Re: Cannot find pdm.dll
If the installation of the OpenSees-Solvers is correct, and you are running it one of the batch files (opensees.bat, openseesp.bat or openseesmp.bat) OpenSees should find that DLL
thanks, it seems to work.
But now i have another error message (see attachment).
You may help one more time.
regards.
regards.
- Präsentation1.jpg (189.13 KiB) Viewed 2409 times
Put the DamageTC3D material into a PlateFiber ND material wrapper, and use that in the layered section
that was already done.
Beton material was the TC3D and Beton ext was the plate fiber material.
But it seems that there is a problem with the rebar fiber. I am not sure.
- Screenshot.jpg (106.5 KiB) Viewed 2396 times
sorry but from the image I cannot see the material types.
Can you share the model?
i can send the .scd file via E-Mail at [email protected] if it is possible.
You can attach it here after zipping it
You have to use PlateRebar for shells, not PlaneStressRebars (which is for 2D plane-stress analysis):
Then you will find an error about the compressive fracture energy being too small...
