Hi Fabiola,
The problem why you couldn't run it was that when you assign your triangular_elements you selected not only faces but also edges and nodes. I reassigned it and now it runs.
But now it asks you to insert peakShearStra for PressureIndependMultiYield
Let us know if you need help
Best, Valentina
Model construction with Python API
Re: Model construction with Python API
- Schema 1.rar
- (623.75 KiB) Downloaded 3 times
Thank you so much Valentina!
I changed the parameters; but why doesn't my analysis run?
I attach my file below.
thanks again!!
thanks again!!
- Schema 1.rar
- (376.97 KiB) Downloaded 5 times
Try this:
Typically static analysis should have a duration of 1 (if you use a linear time series).
After the first analysis you should keep load constant and reset the time to 0 (otherwise it will mess up subsequent time Series)
The the dynamic analysis should have a non-zero duration (I used 25 in this case, due to the duration of your ground motion).
Then, you have to study the analysis settings. Many of them were wrong (system = Linear works only for linear materials, integrator = CentralDifference is for explicit dynamics, not for implicit ones, you don't have any damping, etc..)
Also, I found that applying your self weight assuming the model elastic, gives convergence issues when switching to plastic. So I set the material plastic from the beginning
The analysis was not running because you set a duration of 0. Typically static analysis should have a duration of 1 (if you use a linear time series).
