I hope you're doing well.
I have been trying to modify the values from a rectangular fiber section given the one I previously created. To do this, I want to use the python API, since I wanna perform a Monte Carlo simulation. Despite that I used the following code, the actual section does not modified when the code runs. Could you please help me with an example to properly use the python api for this purpose. I also attach my code and model.
colsection = doc.getPhysicalProperty(4)
colsection_xobj = colsection.XObject
colsection_width = colsection_xobj.getAttribute('Width')
colsection_height = colsection_xobj.getAttribute('Height')
colsection_cornerdiam = colsection_xobj.getAttribute('Corner Rebars Diam')
colsection_botoomdiam = colsection_xobj.getAttribute('Bottom Rebars Diam')
colsection_topdiam = colsection_xobj.getAttribute('Top Rebars Diam')
colsection_leftdiam = colsection_xobj.getAttribute('Left Rebars Diam')
colsection_righttdiam = colsection_xobj.getAttribute('Right Rebars Diam')
######## Set column values
colsection_width.quantityScalar.value = bcolumn[index]
colsection_height.quantityScalar.value = bcolumn[index]
colsection_cornerdiam.quantityScalar.value = phiedge_col[index]
colsection_botoomdiam.quantityScalar.value = phicenter_col[index]
colsection_topdiam.quantityScalar.value = phicenter_col[index]
colsection_leftdiam.quantityScalar.value = phicenter_col[index]
colsection_righttdiam.quantityScalar.value = phicenter_col[index]
colsection.commitXObjectChanges()
In addition there is a way to use the python api to extract the information from the embebed nodes and drift?
All the best,
Salvador
Help for creating rectangular fiber section via python api
- 3levels_regular_infills.zip
- (303.58 KiB) Downloaded 3 times
Salvador Ramos
Re: Help for creating rectangular fiber section via python api
Hi STKO,
I hope you are doing well. If you any example, I will truly appreciated!
Salvador
Salvador
Salvador Ramos
Dear Salvador,
I will work on a code update to make this work.
I'll post here as soon as I have the solution.
Diego
Diego
