Dear stko
I want to ask a question. As we all know, the calculation speed using the overall model is very slow,
If I build two models in STKO, one is the shield tunnel model and the other is the free field model, which is divided into two files.
Can I extract the forces in the free field model in real time (each analysis step) and input them into the shield tunnel model for parallel calculation of seismic response?
Or do you have any good ways to improve the calculation speed of the overall model
Interworking between two STKO models
Re: Interworking between two STKO models
Doing separate model is a mess.
Just try to use parallel computing with OpenSeesMP
Okay,i will try it
Ok, let us know if you have trubles
