I found that this tcl file I wrote might have a problem with the degree of interpretation convergence, but the interpretation continued to the end in the opensses original.
When trying to extract mpco from stko via custom command, the error ele_gauss_id occurs.
I upload error screen and tcl code together.
I want to know what's the problem.
recorder error
recorder error
- gkjop_historic.zip
- (4 MiB) Downloaded 46 times
- analysis_error.png (22.45 KiB) Viewed 1335 times
Re: recorder error
The zeroLengthSection has a bug in the output of results that conflicts with the MPCO recorder.
If you are using the zeroLengthSection simply with un-coupled uniaxial model, just use the zeroLength instead
Re: recorder error
Oh I'm sorry.
I thought I already changed the part, I have mistake for another code.
Thank you very much for letting me know.
Re: recorder error
Excuse me,I also meet a problem like this.If you can tell me how you solve this problem or where the mistake in the code,I will be truly grateful for you help.
Re: recorder error
What problem? could you post a screenshot?
