Add bodyforce
Lei Lei
Add bodyforce
Post by Lei Lei » Sat Jun 01, 2024 1:44 pm
I noticed various body force settings in multiple places within STKO, such as the density of some materials (e.g., PressureDependentMultiYield), the body force in the elements (e.g., quad), and the mass or load in Conditions.
Could you please explain the differences between these settings? Do they impact calculations?
Re: Add bodyforce
Post by kesavapraba » Mon Jun 03, 2024 7:21 am
Density and mass are associated with dynamics analysis, they will not add any static structural loads, as the other (body force and load) do. If you specify density of the material, the equivalent mass at nodes for the elements are internally calculated and assigned. Otherwise, you should manually calculate the mass and assign at the nodes. So, density option for material adds a layer of sophistication.
Lei Lei
Re: Add bodyforce
Post by Lei Lei » Mon Jun 03, 2024 9:01 am
It seems that the body force within the element also contributes to this sophistication.
Re: Add bodyforce
Post by STKO Team » Tue Jun 04, 2024 7:32 am
Yes some elements have the body force as input.
But not all of them, that's why in STKO we developed utilities such as VoulumeForce, FaceForce, EdgeForce... to provide for distributed forces where not available in OpenSees
Lei Lei
Re: Add bodyforce
Post by Lei Lei » Tue Jun 04, 2024 7:47 am
So, for face force, should I consider the thickness of the quad element?
Re: Add bodyforce
Post by STKO Team » Thu Jun 06, 2024 8:10 am
A FaceForce is a pressure F/L^2, so yes, you can compute it as self-weight (F/L^3) times the thickness
Lei Lei
Re: Add bodyforce
Post by Lei Lei » Thu Jun 06, 2024 12:17 pm
Alright, I think Opensees will time the thickness automatically.
Thanks for your reply!
Re: Add bodyforce
Post by kesavapraba » Fri Jun 07, 2024 4:42 am
You need to multiply the self-weight (either in N/m3 or kN/m3) with the corresponding thickness and apply it as face force (STKO automation) along the inplane direction of the quad element.
Lei Lei
Re: Add bodyforce
Post by Lei Lei » Fri Jun 07, 2024 4:51 am
Best wishes!
Re: Add bodyforce
Post by STKO Team » Mon Jun 10, 2024 8:17 am
