Choose Material for TRM modelling
Re: Choose Material for TRM modelling
Post by marafini.f » Tue Nov 09, 2021 7:05 am
You are welcome :)
Larisa GR
Post by Larisa GR » Wed Nov 10, 2021 3:01 pm
Dear Francesca,
Unfortunately I cannot make the orthotropic material work. As you said if I put the same properties it should yield the same results but is not working.
marafini.f wrote:
Thu Nov 04, 2021 11:43 am
it should yield the same response if you put the DamageTC3D in the LayeredShell or if you use the PlateFibers referencing the Orthotropic material,
The error I get is attached.
If in the layeredshell element I put the DamageTC3D materials it works (monotonic and cyclic). But the moment I change to orthotropic+PlateFiber stops working.
The file I'm using is the same you sent me on the 4th of Nov.
Any help will be appreciated
Thanks!
Error Plate Fiber.PNG (80.65 KiB) Viewed 274 times
Post by STKO Team » Thu Nov 11, 2021 9:11 am
How did you set up the orthotropic wrapper?
I would suggest you to keep the elasticity part isotropic and scale only the shear strength so that it will break in shear very soon (for a very small shear stress).
Upon damage, the shear modulus will decrease accordingly G = (1-d)*G0...
This is what I would use for a source material with E = 30000, v = 0.2 and ft = 3 Mpa.
If I want to make the shear strength 100 less then the original one:
Immagine 2021-11-11 100815.png (47.4 KiB) Viewed 272 times
Larisa GR
Post by Larisa GR » Mon Nov 15, 2021 12:17 pm
Dear Francesca,
After introducing the modification you suggested to reduce the shear capacity I still get the same error (see figure attached)
It cannot run the vertical analysis, since it fails to converge in the first increment of the vertical load application.
Any suggestion of what can I try now?
I attached the file just in case it helps.
Thanks!
Error Plate Fiber.PNG (77.99 KiB) Viewed 263 times
MACRO_R_3DCyclic_ortho.rar
(176.18 KiB) Downloaded 38 times
Post by STKO Team » Mon Nov 15, 2021 3:16 pm
We found a bug in compatibility between the Orthotropic Wrapper and the Plate Wrapper... Sorry for the inconvenience. We will fix it in the next few days and let you know.
Larisa GR
Post by Larisa GR » Mon Nov 15, 2021 3:18 pm
Thank you very much!
Larisa GR
Post by Larisa GR » Tue Nov 30, 2021 11:44 am
I was wondering if you managed to solve this bug?
Thank you!
Post by STKO Team » Wed Dec 01, 2021 10:02 am
Yes, it will be released soon in a new version of OpenSees-Solvers.
Larisa GR
Post by Larisa GR » Wed Dec 01, 2021 5:59 pm
Thank you!
Larisa GR
Post by Larisa GR » Fri Dec 10, 2021 11:54 am
Dear STKo Team
Following the topic of modelling the in-plane response of a strengthened shear wall, I'm modelling the TRM layer as strips of Truss Elements (with fiber sections) embedded in the solid that is the Masonry (with the interaction Node To Element links). If I understood correctly, the truss elements should not be discretized, It should have 1 division only, right?.
( the idea is to create vertical truss strips and horizontal ones covering the whole surface in both faces, but before doing anything else I try on one face with the vertical truss)
As physical properties, I created a Fiber section (with a uniaxial material Damage TC1D) and assign it to a special_purpose.truss. The element property is a truss_elements.truss.
The problem is that when I run it I cannot see any result in the truss, the section.fiber.damage is always zero (see picture attached).
I don't know if I'm failing at creating the interaction of the trusses with the solid or if it is the meshing or sth else.
I attached also the scd file so you can take a look and help me with this issue.
as always, thank you very much for your help and guidance.
MACRO_R_1D_1.rar
(138.61 KiB) Downloaded 5 times
Error Truss.PNG (429.78 KiB) Viewed 140 times
