Material Test
thanh2611
Material Test
Post by thanh2611 » Sat Feb 15, 2020 6:28 am
I am trying to do the material test but it is some errors in the command lines. I attached the specific problem below
Thank you so much
Re: Material Test
Post by STKO Team » Sat Feb 15, 2020 8:51 am
Dear Thanh,
That error happens when the opensees we generate for the material testing issues an error. So it does not write the output.txt file, so the python script will give you that error saying that it cannot find the "output.txt" file.
This can happen if you are using the DamageTC3D material with a version of OpenSEES that does not have that material model. That material model is only available in the OpenSEES version we distribute with STKO. Did you download STKO+OpenSEES? or are you using your own version of OpenSEES?
thanh2611
Re: Material Test
Post by thanh2611 » Mon Feb 17, 2020 1:14 am
I used my own model of Opensees 3.0.3. I dowloaded the STKO trial but I do not know where is Opensees version in STKO
Re: Material Test
Post by STKO Team » Tue Feb 18, 2020 9:04 am
Dear thanh,
If you downloaded STKO+OpenSEEs, then OpenSees.exe should be located here: "C:\Program Files\STKO\opensees\bin\OpenSees_303\OpenSees.exe".
If you downloaded only STKO, that you don't have our version of STKO. Please check the existance of the abovementioned executable.
Let us know
