Dear STKO Team!
I'm approacing to masonry micro-modeling and I have to reproduce an experimental diagonal test on a simple panel. I red about different strategies proposed by Petracca and others authors in the article: "Micro-scale continuous and discrete numerical models for nonlinear analysis of masonry shear walls". As you can see i have only horizontal mortar joints instead in the vertical ones there's no mortar; so which physical and element properties would you suggest to simulate interfaces between bricks? Currently my model is based on the 2D-C solution.
Thanks for the support!
- masonry_panel.jpg (131.06 KiB) Viewed 1439 times
- DIAGONAL_TEST_MASONRY.zip
- (209.83 KiB) Downloaded 19 times
- micro-modeling strategies.jpg (118.05 KiB) Viewed 1439 times
Re: masonry micro-modeling
You can keep working with the 2D-C model.
But in the brick-to-brick interface you can use a different material with a very small (almost 0) tensile strength
Great! But shall i carry on with the DamageTC3D? Maybe assigning brick's parameters in compression and quite small values in tension or shall I go for an other material?
Thanks again!
Thanks again!
you can go on with DamageTC3D (or also ASDConcrete3D).
with:
with:
- small tensile strength/fracture energy (but not exactly zero)
- high compressive strength/fracture energy (so that it behaves like hard contact in compression)
- pdft and pdfc = 0, so that you don't have plastic deformation
