Custom recorder error
Lei Lei
Post by Lei Lei » Thu Apr 11, 2024 2:56 am
Dear STKOteam,
I used two beam elements and a zerolengthsection element to simulate a beam with a gap in its middle. Just like figure1.
All the elements are assigned with a fiber section. I use the element recorder to output the elements' local force.
However, the beam on the gap's left can output successfully while the right beam can't.
Just like figure2, 3, and 4. The gap is element 35. I selected an element output for the left (element 19)and right(element 16) beams respectively.
The weird thing is that the right beam can output Stress-Stain properly.
Figure1
Figure2
Figure3
Figure4
Re: Custom recorder error
Post by kesavapraba » Mon Apr 15, 2024 1:54 pm
Hi, I can only partially understand your issue since no details are there about the type of element etc.! Can you please send me the model?
Lei Lei
Post by Lei Lei » Tue Apr 16, 2024 2:09 pm
Dear STKOteam,
The model described is shown below:
model description
The problem is that I can output the local force of elements from the left curvilinear beam with a customer recorder script while the right beam just have the first column for time step.
However, for the stress-strain data of the beam's fiber sections, I can successfully output it for both cuvilinear beam.
My recorder scrip is as below, in which the element 19 is on the left beam while the element 16 is on the right.
recorder script
Post by STKO Team » Thu May 09, 2024 12:25 pm
please share your script/file
Lei Lei
Post by Lei Lei » Thu May 09, 2024 1:30 pm
Here, I provide a similar simple case and the recorder scrips are in the 'custom output' command.
Post by STKO Team » Fri May 10, 2024 4:03 pm
Look at the end of the line where you define the recorder that is not working...
You are not using a regular semicolon! you are using a special character that is not recognized by tcl
Lei Lei
Post by Lei Lei » Sat May 11, 2024 4:50 am
OMG, what a careless mistake.!
Thank you for your kindness and attentiveness~
Best wishes~
Post by STKO Team » Mon May 13, 2024 8:18 am
