I modelled a pile - a soli interaction - much like the one in the instructional video. I have set it up in the same way as in the video. However, I encountered the following problems.
LinearCrdTransf3d::getLocalAxes
vector v that defines plane xz is parallel to x axis
BeamContact3Dp::setDomain(): Error initializing coordinate transformationdestroying lib handle: 00007FFD51EA0000 ... 0000000000000000
Could you kindly help me solve this problem? I look forward to hearing from you!
Shukai Chen
soli-pile interaction analysis problem
- FE model.zip
- (550.72 KiB) Downloaded 15 times
Re: soli-pile interaction analysis problem
You should assign the cylindrical local axes to the interaction, not to the soil.
