Non-compatible results between Openseespy and STKO
angieosca
Post by angieosca » Thu Jul 21, 2022 7:45 pm
Dear Asdeasoft team,
I am currently working on two models in 2D in Openseespy and STKO in order to compare results and be sure of that my models in STKO are working properly. However, the results are different between both softwares. I have revised the models in STKO and I cannot find what I'm doing wrong.
I would be thankful if you could help me to find the error.
I attach one of my models, the simplest of all.
4. Modelo palito.rar
(421.34 KiB) Downloaded 7 times
Re: Non-compatible results between Openseespy and STKO
Post by STKO Team » Mon Jul 25, 2022 9:03 am
The OpenSees core underneath is the same (STKO is just a GUI) so the results should be the same.
If you see differences in the output, there are differences in the input.
For example,
in your python file you put the second node at y = 1.65.
later on you declare the Lcol = 1.65 * 1000... but the node is still a 1.65.
while in STKO the node is a y = 1650
Please double check your model
angieosca
Post by angieosca » Fri Aug 05, 2022 7:53 pm
I have solved the situation with the simplest model. Now I am trying to compare the results between a 2D one frame structure but the reactions at the base that I get from STKO are different from the reactions that I get from Spyder. I have checked the materials, the interactions and everything but nothing seems to be wrong. I thought it could be because I was assigning wrong the EqualDOF interaction but it seems to be right.
I wonder if you could help me out to solve this doubt.
Thank you in advance
Ejercicio2.rar
(159.46 KiB) Downloaded 6 times
Post by STKO Team » Mon Aug 22, 2022 10:58 am
You did not include this file
from seccion import *
