Dear Team,
I have a 3D wave propagation model with internal source and I want to absorb the wave only at one face of the model. I have tried using the ASDAbsorbingBoundary3DAuto element, but apparently only works if it is assigned to the entire outer boundary of the domain. I also tried using an absorbing volume with the ASDAbsorbingBoundary3D option but it was impossible to achieve convergence. Could you give me some suggestions please ?
Thank you very much
Absorbing boundary at only one face
Re: Absorbing boundary at only one face
If you only want to absorb outgoing waves coming from an internal source, you can simply use the DristributedLK3D condition.
If you share your model and a sketch of what you want to do we can help you
Thank you very much, DristributedLK3D solved the issue
Exactly.
The DistributedLK are just L-K dashpots, whose aim is to absorb outgoing waves.
The ASDAbsorbingBoundary instead is an assembly of a Free-field column (to impose the 1D free-field motion) and LK dashpots to absorb outgoing waves. It should be used when the input comes from outside the domain
