How to use Physical Properties for BeamColumn element
admin
Site Admin
Post by admin » Thu Jun 27, 2019 1:25 pm
In this forum we'll talk about P.P. for BeamColumn: how to define and assign it to the element.
Sabino
Re: How to use Physical Properties for BeamColumn element
Post by Sabino » Thu Jun 27, 2019 4:18 pm
Hello to everybody! :)
I would know how to use element properties for Beamcolumn element. I tried to assign them to the element but I have the following error in STKO:
“Python error : Error: cannot find "Option" attribute: File "C:/Program Files/STKO\external_solvers\opensees\mpc_solver_write_input.py", line 247, in write_tcl write_tcl_int(out_dir) File "C:/Program Files/STKO\external_solvers\opensees\mpc_solver_write_input.py", line 175, in write_tcl_int write_element.write_geom(doc, pinfo) File "C:/Program Files/STKO\external_solvers\opensees\utils\write_element.py", line 105, in write_geom __write_geom_domain(pinfo, mesh_of_geom.edges, phys_prop_asn.onEdges, elem_prop_asn.onEdges) File "C:/Program Files/STKO\external_solvers\opensees\utils\write_element.py", line 92, in __write_geom_domain elem_module.writeTcl(pinfo) File "C:/Program Files/STKO\external_solvers\opensees\element_properties\beam_column_elements\dispBeamColumn.py", line 124, in writeTcl internalBeamColumnElement.writeTcl_internalBeamFunction(pinfo) File "C:/Program Files/STKO\external_solvers\opensees\element_properties\beam_column_elements\internalBeamColumnElement.py", line 475, in writeTcl_internalBeamFunction raise Exception('Error: cannot find "Option" attribute') Abort Command: RunAnalysis”
How can I solve it?? Any video tutorial about this topic? :roll:
ValentinASDEA
Post by ValentinASDEA » Fri Jun 28, 2019 10:07 am
Hi Sabino!
No panic! That error is due to the fact that you assigned the wrong p.p. to the dispBeamElement.
For example, you cannot directly assign an Elastic Section or a Fiber Section or a Section Aggregator. You need to create a Physical Property -> Special Purpose -> Beam-Column -> BeamSectionProperty. In that special purpose property, you can choose the section that you want to assign (i.e. the one that you assigned before in the wrong way), and the integration rule.
Anyway I attached a video of STKO basic workflow from the pre-processor to the post processor:
https://www.youtube.com/watch?v=0lLeIZpLwlQ
lanaroady
Post by lanaroady » Fri Aug 02, 2019 12:41 pm
Hi Sabino!
I just want to ask at the moment you have no version of your library for MacOS. Is it possible to release it?
MassimoPetracca
Post by MassimoPetracca » Sat Aug 03, 2019 8:38 am
We are currently working on releasing STKO on other operating systems, including MacOS. For the moment however you should use a virtual machine.
NicolaTarque
Post by NicolaTarque » Thu Mar 12, 2020 5:57 pm
I hope you can guide me with this question. What is the difference between E of a Material Uniaxial Elastic and Section Elastci. According to your tutorials I see that in the second one the E is the elastic modulus of concrete, however the E in the first one is 100 times greater than the elastic modulus. Could you give me some literature for that?
Thanks,
Nicola
NicolaTarque
Post by NicolaTarque » Thu Mar 12, 2020 10:53 pm
Hi, I believe you add a rigid material (great E) because it is related to the hinge and not to the elastic element.
Thanks,
Nicola
