Dear STKO team:
I am trying to add diagonal braces to a frame, and I want these two braces to not connected each other in between. However, when I merge the model, a vertex is automatically created at the intersection point of the braces. Is there any way to remove this vertex?
How to create two trusses that intersect but are not connected?
Seismic analysis, structural dynamic
Re: How to create two trusses that intersect but are not connected?
Hi wsadwsad,
Try to use 'Make wire' instead of 'Merge' command. Let me know if it is what you needed.
Best wishes,
Valentina
Best wishes,
Valentina
It perfectly resolved my issue. Thank you very much!ValentinaSB wrote: ↑Thu May 11, 2023 7:57 amHi wsadwsad,
Best wishes,
Valentina
