The same issue discussed in this post few days ago:
viewtopic.php?f=27&t=73#p112
Importing from tcl
Re: Importing from tcl
I have just downloaded STKO 1.1.0 and i want to use the mpco but I don't have this directory "C:\Program Files\STKO\opensees\bin\OpenSees_303". I dont know where do I have to place my tcl files or my Opensees.exe in order to make this work. Thank you very much. Kind regards.
probably you have not installed Opensees.
You can read this discussion:
viewtopic.php?f=33&t=1644&p=2070&hilit= ... view#p2070
I could not find this path in my STKO Program. Had it been changed?MassimoPetracca wrote: ↑Thu Nov 07, 2019 3:07 pmDear Ali,
You don't need to install the HDF5 library by yourself. The necessary redistributables are located in the STKO install directory (typically in "C:\Program Files\STKO\opensees\bin\hdf5").
If for some reason you want to install HDF5 by yourself, you need a specific version: 1.10.1. Unfortunately the installer for that version is not available anymore on the HDF5 website, but the source cose is there and you can compile it.
If you downloaded the STKO+OpenSees package, then you already have OpenSees.exe (version 3.0.3) located in "C:\Program Files\STKO\opensees\bin\OpenSees_303".
There is also a batch script "C:\Program Files\STKO\opensees\opensees_303.bat" that takes care of setting up the necessary environment variables so that OpenSees can find HDF5 and all other dependencies.
So to summarize, what I suggest is to run your model in this way:Note: If you downloaded STKO alone (no OpenSees.exe included) and you are using your own OpenSees.exe, you can just copy your OpenSees.exe in "C:\Program Files\STKO\opensees\bin\OpenSees_303" and you are ready to go, as all the other dependencies are already there.
- Go in the directory where you have your TCL files
- Open a terminal window
open_terminal.PNG- Type the following commad:
"C:\Program Files\STKO\opensees\opensees_303.bat" your_tcl_script.tcl
Let me know if this solves your problem.
Best regards
Massimo Petracca
That location only existed in previous version of STKO that included OpenSees. Now OpenSees is not included anymore with STKO, that's why you don't find that folder.
Anyway, if you need the HDF5 dlls, they are in the C:\Program Files\STKO (hdf5.dll, szip.dll, zlib.dll)
