Drift raio
Drift raio
Hello!STKO users and STKO Team,
I saw a topic on the forum, STKO team gives a file to get the drift raio, this is exactly what I need! (The topic i will show in the attachment) But I used this Python API in STKO post processor, and then attachment error occurred. I have never studied python, I have no idea how to solve this problem. I conducted a search, some people said that the reason for this error is not installed utils, but the problem is not solved after installation. I would be grateful if you could give me some help.
- the topic what i saw
- python.png (453.78 KiB) Viewed 1392 times
- the error
- error.jpg (289.75 KiB) Viewed 1393 times
Re: Drift raio
I just answered in the other post
Re: Drift raio
If you know a bit of Python, you can modify the script I sent you, so that every data that we put on the Plot windows, you can write it to a text file.
Give it a try, if you can't do it, we will help you
Re: Drift raio
I don 't know much about python, so I ask for help from my partner, but he does not understand the relevant content of the building, so we fail. So If you can help me, I will be grateful.
Re: Drift raio
Try this:
In each line you have the time + the drifts at each floor
It will create a folder with 1 file for each column. In each file you have 1 line for each time step.In each line you have the time + the drifts at each floor
