question about kit solver installation
samu.00
Post by samu.00 » Tue May 21, 2024 7:49 pm
Good evening. How can I install kit solver? Thank you.
In the contact material how can I calculate all the associated parameters?
Re: question about kit solver installation
Post by kesavapraba » Wed May 22, 2024 4:23 am
Hi, I think you meant OpenSees solvers. In that case, you can download it from Prof. Nicola's researchgate page (link below).
samu.00
Post by samu.00 » Thu Jun 13, 2024 10:57 am
In all the models I have built it's going to continue appearing this error but I don't understand from which it could be caused.
Problems starting simulation
Captura de pantalla 2024-06-13 125156.png (21.9 KiB) Viewed 665 times
Post by STKO Team » Tue Jun 18, 2024 8:12 am
It's probably because you are using sections->Iso2spring or sections->Uniaxial.
There was a small bug in the input (an extra unused argument)
It will be fixed in the next STKO release. In the meantime, unzip this folder (
sections_bugfix.zip
(2.6 KiB) Downloaded 23 times
) and copy/replace the 2 python files you will find inside, in the STKO installation folder:
C:\Program Files\STKO\external_solvers\opensees\physical_properties\sections
samu.00
Post by samu.00 » Thu Jun 27, 2024 9:54 am
I tried to do what you recommended but I noticed that the files are already in the folder. I tried to replace them with files you have sent me but STKO's continuing to give me the same problem.
Captura de pantalla 2024-06-27 114750.png (71.55 KiB) Viewed 277 times
samu.00
Post by samu.00 » Wed Jul 10, 2024 11:47 am
I've found problems with the simulation of a fyle which I have attached below. It refers to the reproduction of a 4 point test. The simulation starts but after it gives error of fail. The file's name is "primo campione".
non funzion 2.0.zip
(8.25 MiB) Downloaded 3 times
